| Danny
Upisano: Sri Ruj 16, 2009 7:07 pm Naslov poruke: Mitsubishi A6M2a zero |
Pozdrav!
Uskoro cu zapocet ovu maketu
,pa imam par pitanja u vezi boja,zanima me koja bi bila boja cockpita,naime u sastavnici kaze cockpit color (mitsubishi)??? I green (mitsubishi) koje bi to bile mjesavine.Unaprijed hvala! _________________ Overhead the albatross hangs motionless upon the air,and deep beneath the rolling waves in labyrinths of coral caves
| CCCP Administrator
Upisano: Sri Ruj 16, 2009 7:31 pm Naslov poruke: |
O, super maketa, složil sam jednu takvu. Isto me zbunjivala ta boja, pa sam bacil u jedinu zelenu koju sam imo, Revell 65, i dobra je, ali ipak malo pretamna... stavi si nešto poput Revell 68 ili malo svjetlije... _________________ MK David Schwarz
ZMMS |
| darko
Upisano: Sri Ruj 16, 2009 9:38 pm Naslov poruke: |
Citat sa: http://www.ww2f.com/modelling/16032-cockpit-colors-ww2-japanese-aircraft.html
Guys, I think I find the mix of colors, but I really want a colored example, if possible.
Here is what I found:
Mitsubishi Interior Green
Gunze Mr. Color
6-Green 15%,
7-Brown 20%,
4-Yellow 65%
Tamiya
X5-Green 10%,
X9-Brown 20%,
X8-Lemon Yellow 70%
Aeromaster Warbird Acrylics
1096
Nakajima Interior Green
Gunze Mr. Color
1-White 82%,
6-Green 10%,
4-Yellow 5%,
7-Brown 3%
Tamiya
White 92%,
X1-Black 3%,
X5-Green 3%,
X8-Lemon Yellow 2%
1093 |
| P-51
 | | Član od: 24 Ožu 2006 | | Poruke: 3474 | | Mjesto: Drniš/Šibenik |
Upisano: Sri Ruj 16, 2009 10:51 pm Naslov poruke: |
| Ima u LOM-a Japan interior green, vidio jučer u St. |
| darko
Upisano: Sri Ruj 16, 2009 11:51 pm Naslov poruke: |
Ako misliš na MM2, koliko se sječam to nije to (ali provjeri svakako).
Pozdrav ! |
| 0viking0 Moderator
Upisano: Čet Ruj 17, 2009 8:27 am Naslov poruke: |
| P-51 Napisao/la: | | Ima u LOM-a Japan interior green, vidio jučer u St. |
Mislim da su Nakajima i Mitsubisji koristili različite "japan interior green"... Ak zvuči blesavo to kaj sam napisao Nakajima u ovom postu - puno Zeroa je proizvedeno u Nakajiminim pogonima tako da nemaju svi istu boju unutrašnjosti stajnog trapa i kokpita. Znam po tome što sam radio svog i mučio me isti problem. ...Zaboravio sam samo kak raspoznati iz koje je tvornice pojedini model... _________________ paulusvictor |
Upisano: Čet Ruj 17, 2009 9:46 am Naslov poruke: |
Što se tiče MM boja za Japance, bježi od njih. Sve su rađene davno po zastarjelim referencama. Najbolje ti je koristit Gunze od boja dostupnih kod nas, iako je WEM najbolji po tonovima. 0Viking0 je spomenuo razlike u boji kokpita ovisno o tvornici u kojoj je Zero proizveden (Mitsubishi/Nakajima), ali je važno spomenuti da je i boja samog aviona različita ovisno o tvornici. Mitsubishi boja unutrašnjosti je vrlo slična US Interior Green, samo je zelenija. Mislim da je jedna od stvari za prepoznavanje kod A6M2 servisna tablica kod repa. Čini mi se da je Mitsubishijeva velika i kvadratna kao ova na box artu, a Nakajimina manja i pravokutna. Kod ovih ranih varijanti je većina zeroa i tako proizvedena u matičnoj tvrtki, dok se kasnije, povećanjem prizvodnje, situacija okrenula...Inače, boja tzv. Ameiro za vanjske površine jako liči i rađena je po uzoru na RLM 02, ali je Mitsubishijeva vuče na sivo, a Nakajimina na više smeđe... _________________
| Danny
Upisano: Uto Lis 20, 2009 8:52 pm Naslov poruke: |
mali update.Boju za unutrasnjost sam kemijal kak je Darko rekel,znaci zelena,smedja i zuta,dal sam pogodio nijansu neznam,jednostavno nisam se htio zamarat sa tocnoscu nijansi.
Vanjska boja bi trebala biti neka kemija sive,al da malo vuce na zelenu,ak sam dobro skuzil???Stavljen primer,slikice
| Darth Maul
 | | Član od: 16 Lis 2005 | | Poruke: 101 | | Mjesto: Pretetinec |
Upisano: Uto Lis 20, 2009 9:39 pm Naslov poruke: |
Ups.... kasnim.
Dakle, A6M2 Model 11 je radio samo Mitsubishi.
Vanjska boja je podlozna debati ali radi se o sivoj sa smeđe-zelenim odsjajem (zabavno, a?)
Model Master mix bi bio:
RLM02 s malo bijele. Nije vic.
Ako imaš Humbrol, 168 Hemp nije loša boja.
Zvuči čudno ali je tako. Boja zadnjeg dijela trupa je upitna - ili se radi o istrošenoj osnovnoj sivoj (vidi gore), ili se radi o drugoj boji. Izbor je tvoj, u svakom slučaju boja je svjetlija i sivija.
E sad, budući da je tvoj Zero baš rađen od strane Mitsubishija, evo par smjernica (kokpit zelenu preskačem):
- trup ispod stakla iza kabine je crn kao i pokrov instrumentne ploče
- unutrašnjost ležišta kotača, kao i poklopci istih su bojani istom sivom kao i cijeli zrakoplov
- noge su polumat crne
- krakovi propelera su prirodni aluminij sprijeda a straga tamno smeđi cca 30059
- spiner je u boji aluminija (obojan, ne sirovi metal)
- platnene povrsine su tamnije sive boje bez žućkaste nijanse - dodaj kap crne u osnovni mix _________________ Ja - Mario
Proud to be Međimurec... |
| dr. vlado
Upisano: Sri Lis 21, 2009 9:10 pm Naslov poruke: |
Dobro uradjen cockpit. Svidja mi se  |
| Aranza
Upisano: Čet Lis 22, 2009 9:09 am Naslov poruke: |
Osim što je lijepo urađen, sve će se vidjeti. Samo naprijed. _________________
Španac |
| Danny
Upisano: Ned Stu 01, 2009 11:41 pm Naslov poruke: |
Pozdrav!
Danas sam zavrsio sa washom i decalima,
prvi put sam probao raditi wash sa vodenim temperama
pa me zanima vase misljenje dal je to ok!Inace blic mi je malo ubio boju
pa zgleda kao bijela,al nije ,u zavrsni lak cu dodat kap rlm02 da dobije jos malo zelenkasti sjaj
Mozda jos malo drybrusha i to bi bilo to
nemam namjeru radit puno oguljenja! _________________ Overhead the albatross hangs motionless upon the air,and deep beneath the rolling waves in labyrinths of coral caves
| tole
Upisano: Pon Stu 02, 2009 9:18 am Naslov poruke: |
Baš dobro izgleda, taman je wash, nemoj više jer ćeš pretjerat. _________________
Upisano: Pon Stu 02, 2009 3:17 pm Naslov poruke: |
Ovi Hinomarui na krilima mi izgledaju neobično pozicionirani? _________________
| dr.zeko
 | | Član od: 23 Sij 2008 | | Poruke: 178 | | Mjesto: novi sad |
Upisano: Sri Stu 04, 2009 1:31 pm Naslov poruke: |
Meni je uber  _________________ dr.z |
