Mitsubishi A6M2a zero
Danny
Član od: 19 Pro 2008
Poruke: 931
PorukaUpisano: Sri Ruj 16, 2009 7:07 pm    Naslov poruke: Mitsubishi A6M2a zero Citiraj ovaj komentar
Pozdrav!
Uskoro cu zapocet ovu maketu
,pa imam par pitanja u vezi boja,zanima me koja bi bila boja cockpita,naime u sastavnici kaze cockpit color (mitsubishi)??? I green (mitsubishi) koje bi to bile mjesavine.Unaprijed hvala!
CCCP
Član od: 14 Ožu 2009
Poruke: 785
PorukaUpisano: Sri Ruj 16, 2009 7:31 pm    Naslov poruke: Citiraj ovaj komentar
O, super maketa, složil sam jednu takvu. Isto me zbunjivala ta boja, pa sam bacil u jedinu zelenu koju sam imo, Revell 65, i dobra je, ali ipak malo pretamna... stavi si nešto poput Revell 68 ili malo svjetlije...
MK David Schwarz
ZMMS
darko
Član od: 10 Ruj 2006
Poruke: 2356
Mjesto: Daruvar
PorukaUpisano: Sri Ruj 16, 2009 9:38 pm    Naslov poruke: Citiraj ovaj komentar
Citat sa: http://www.ww2f.com/modelling/16032-cockpit-colors-ww2-japanese-aircraft.html
Guys, I think I find the mix of colors, but I really want a colored example, if possible.
Here is what I found:
Mitsubishi Interior Green
Gunze Mr. Color
6-Green 15%,
7-Brown 20%,
4-Yellow 65%
Tamiya
X5-Green 10%,
X9-Brown 20%,
X8-Lemon Yellow 70%
Aeromaster Warbird Acrylics
1096
Nakajima Interior Green
Gunze Mr. Color
1-White 82%,
6-Green 10%,
4-Yellow 5%,
7-Brown 3%
Tamiya
White 92%,
X1-Black 3%,
X5-Green 3%,
X8-Lemon Yellow 2%
1093
Poruke: 3476
PorukaUpisano: Sri Ruj 16, 2009 10:51 pm    Naslov poruke: Citiraj ovaj komentar
Ima u LOM-a Japan interior green, vidio jučer u St.
darko
Poruke: 2356
Mjesto: Daruvar
PorukaUpisano: Sri Ruj 16, 2009 11:51 pm    Naslov poruke: Citiraj ovaj komentar
Ako misliš na MM2, koliko se sječam to nije to (ali provjeri svakako).
Pozdrav !
Poruke: 2977
PorukaUpisano: Čet Ruj 17, 2009 8:27 am    Naslov poruke: Citiraj ovaj komentar
P-51 Napisao/la:
Mislim da su Nakajima i Mitsubisji koristili različite "japan interior green"... Ak zvuči blesavo to kaj sam napisao Nakajima u ovom postu - puno Zeroa je proizvedeno u Nakajiminim pogonima tako da nemaju svi istu boju unutrašnjosti stajnog trapa i kokpita. Znam po tome što sam radio svog i mučio me isti problem. ...Zaboravio sam samo kak raspoznati iz koje je tvornice pojedini model...
paulusvictor
PorukaUpisano: Čet Ruj 17, 2009 9:46 am    Naslov poruke: Citiraj ovaj komentar
Što se tiče MM boja za Japance, bježi od njih. Sve su rađene davno po zastarjelim referencama. Najbolje ti je koristit Gunze od boja dostupnih kod nas, iako je WEM najbolji po tonovima. 0Viking0 je spomenuo razlike u boji kokpita ovisno o tvornici u kojoj je Zero proizveden (Mitsubishi/Nakajima), ali je važno spomenuti da je i boja samog aviona različita ovisno o tvornici. Mitsubishi boja unutrašnjosti je vrlo slična US Interior Green, samo je zelenija. Mislim da je jedna od stvari za prepoznavanje kod A6M2 servisna tablica kod repa. Čini mi se da je Mitsubishijeva velika i kvadratna kao ova na box artu, a Nakajimina manja i pravokutna. Kod ovih ranih varijanti je većina zeroa i tako proizvedena u matičnoj tvrtki, dok se kasnije, povećanjem prizvodnje, situacija okrenula...Inače, boja tzv. Ameiro za vanjske površine jako liči i rađena je po uzoru na RLM 02, ali je Mitsubishijeva vuče na sivo, a Nakajimina na više smeđe...
Danny
Poruke: 931
PorukaUpisano: Uto Lis 20, 2009 8:52 pm    Naslov poruke: Citiraj ovaj komentar
mali update.Boju za unutrasnjost sam kemijal kak je Darko rekel,znaci zelena,smedja i zuta,dal sam pogodio nijansu neznam,jednostavno nisam se htio zamarat sa tocnoscu nijansi.
Vanjska boja bi trebala biti neka kemija sive,al da malo vuce na zelenu,ak sam dobro skuzil???Stavljen primer,slikice
Darth Maul
Poruke: 101
Mjesto: Pretetinec
PorukaUpisano: Uto Lis 20, 2009 9:39 pm    Naslov poruke: Citiraj ovaj komentar
Ups.... kasnim.
Dakle, A6M2 Model 11 je radio samo Mitsubishi.
Vanjska boja je podlozna debati ali radi se o sivoj sa smeđe-zelenim odsjajem (zabavno, a?)
Model Master mix bi bio:
RLM02 s malo bijele. Nije vic.
Ako imaš Humbrol, 168 Hemp nije loša boja.
Zvuči čudno ali je tako. Boja zadnjeg dijela trupa je upitna - ili se radi o istrošenoj osnovnoj sivoj (vidi gore), ili se radi o drugoj boji. Izbor je tvoj, u svakom slučaju boja je svjetlija i sivija.
E sad, budući da je tvoj Zero baš rađen od strane Mitsubishija, evo par smjernica (kokpit zelenu preskačem):
- trup ispod stakla iza kabine je crn kao i pokrov instrumentne ploče
- unutrašnjost ležišta kotača, kao i poklopci istih su bojani istom sivom kao i cijeli zrakoplov
- noge su polumat crne
- krakovi propelera su prirodni aluminij sprijeda a straga tamno smeđi cca 30059
- spiner je u boji aluminija (obojan, ne sirovi metal)
- platnene povrsine su tamnije sive boje bez žućkaste nijanse - dodaj kap crne u osnovni mix
Ja - Mario
Proud to be Međimurec...
Vidi profil korisnika Pošalji privatnu poruku Posjeti web-site AIM Yahoo Messenger MSN Messenger
dr. vlado
Član od: 12 Ožu 2008
Poruke: 1411
PorukaUpisano: Sri Lis 21, 2009 9:10 pm    Naslov poruke: Citiraj ovaj komentar
Dobro uradjen cockpit. Svidja mi se Very Happy
Aranza
Član od: 25 Lis 2007
Poruke: 3458
Mjesto: Pula
PorukaUpisano: Čet Lis 22, 2009 9:09 am    Naslov poruke: Citiraj ovaj komentar
Osim što je lijepo urađen, sve će se vidjeti. Samo naprijed.
Španac
Danny
Poruke: 931
PorukaUpisano: Ned Stu 01, 2009 11:41 pm    Naslov poruke: Citiraj ovaj komentar
Pozdrav!
Danas sam zavrsio sa washom i decalima,
prvi put sam probao raditi wash sa vodenim temperama
pa me zanima vase misljenje dal je to ok!Inace blic mi je malo ubio boju
pa zgleda kao bijela,al nije Very Happy ,u zavrsni lak cu dodat kap rlm02 da dobije jos malo zelenkasti sjaj
Mozda jos malo drybrusha i to bi bilo to
nemam namjeru radit puno oguljenja!
tole
Poruke: 1117
PorukaUpisano: Pon Stu 02, 2009 9:18 am    Naslov poruke: Citiraj ovaj komentar
Baš dobro izgleda, taman je wash, nemoj više jer ćeš pretjerat.
PorukaUpisano: Pon Stu 02, 2009 3:17 pm    Naslov poruke: Citiraj ovaj komentar
Ovi Hinomarui na krilima mi izgledaju neobično pozicionirani?
dr.zeko
Član od: 23 Sij 2008
Poruke: 178
Mjesto: novi sad
PorukaUpisano: Sri Stu 04, 2009 1:31 pm    Naslov poruke: Citiraj ovaj komentar
Meni je uber Very Happy
dr.z
