Žuti V na Bf-109
Poruke: 5000
PorukaUpisano: Ned Kol 30, 2020 12:25 am    Naslov poruke: Žuti V na Bf-109 Citiraj ovaj komentar
Pitanje ima li tko dobrih fotki ili profila di se vidi točna pozicija žute oznake V koja se koristila na kraju rata na Luftwaffeovim lovcima i dali je bila točno propisana oblika i veličine ili je bilo više varijacija nagiba , širina krakova ,dužina.
I ako je moguće malo objašnjenje kada je uvedena i do kada se koristila ,koliko kužim zapravo mali broj zrakoplova ju je koristio ,dali se koristila zajedno sa žutim vrhovima krila ili ne?
Poruke: 5000
PorukaUpisano: Ned Kol 30, 2020 8:42 pm    Naslov poruke: Citiraj ovaj komentar
da sam sebi odgovorim barem na drugi dio pitanja....
Citat:
Copy to: Luftflotte Reich, Luftflotte 6, Lw.Kdo. Südost, (Roman) I. Fliegerkorps, Komm. Gen. der Deutschen Luftwaffe in Ungarn, 15. Flakdivision, OC Luftflotte Transport Einsatzstab Banat, Liaison Detachment of Luftflotte 4 with Royal Hungarian 102. Flieg. Brig., 3.(F)/1221, 1.(F)/Nacht, Wekusta 76, Schleppgruppe 2, TG 3:
The enemy is operating German a/c types on the Rumanian front, partly with German markings. In order to identify with certainty our own a/c, the following additional identity marking in “yellow paint” is ordered for the area of Luftflotte 4, for operational a/c Me 109, Fw 190, Ju 87, Ju 88, Ju 188, Hs 129, He 171+ and Do 217:
1) Round the fuselage in front of the ailerons ŁHöhenflosseŁ a ring 40 cm. wide.
2) Under the left wing, the entire wing depth a “V” open in the direction of flight with a 45ş angle and a leg breadth of 25 cm. The legs of the open “V” are to be extended over the leading edge to a depth of 60 cm., so that recognition is also possible from above.
The prescribed identification is to be brought into use forthwith. Completion is to be reported by 25/9/0400 hrs. From then onwards up to 30 km. distance from the front “open fire” on all named a/c without the new marking (order follows).
Lw.Kdo. Südost is requested to associate itself with this regulation on the Rumanian front.
Ali ako tko ima kakvu dobru fotku ili profil slobodno neka okaći...
Alkett
Član od: 19 Velj 2017
Poruke: 104
Mjesto: Crikvenica
PorukaUpisano: Sub Ruj 05, 2020 1:02 am    Naslov poruke: Citiraj ovaj komentar
Poky,
nisu je koristili samo lovci, kako i piše u naredbi. Na ovom linku imaš nekoliko fotki s tom oznakom na Ju-87 G-2 W.Nr. 494193, pilot Geschwaderkommodore (1.VIII.1944 - 8.II.1945) Obstlt. Hans-Ulrich Rudel, Stab SG 2 'Immelmann', Görgenyaroszfalu/Ungarn. Rudel je pilotirao ovom stukom u periodu kolovoza1944 do 22 listopada, 1944.
https://www.tapatalk.com/groups/72nd_aircraft/junkers-ju-87-g-2-h-u-rudel-t6308.html¸
Ju 87, SG2 Major Kurt Lau 10.(Pz)SG2:
Fw 190 F:
Bf 109 G14, JG53, Erich Hartmann Veszprem Mađarska, Veljača 1945.
https://www.tapatalk.com/groups/hyperscale/1-32-revell-bf-109g-6-14-maj-erich-hartmann-jg-53--t511844.html
Alkett
Poruke: 104
Mjesto: Crikvenica
PorukaUpisano: Sub Ruj 05, 2020 10:51 pm    Naslov poruke: Citiraj ovaj komentar
Za Bf 109 od pravih fotografija vidim ih na našim Bf 109 G. Evo poznati sken.
Ima još jedna fotka u u 5. poglavlju 'Messerschmitt Bf 109 Vol. II' (Ciglić) na stranici 173. Gornja fotografija, gdje se vidi položaj oba kraka slova V.
Vjerujem da je knjiga pri ruci.
I našao sam fotografiju Hartmannovog Bf 109 G. Pozicije 'V' oznake se razlikuju od nas do njih (JG53):
pozdrav,
Alkett: poruka promijenjena dana: Ned Ruj 06, 2020 11:12 pm; prepravljeno ukupno 1 puta
Poruke: 5000
PorukaUpisano: Ned Ruj 06, 2020 4:05 am    Naslov poruke: Citiraj ovaj komentar
Fala ti Alkett znam za druge zrakoplove da su i oni koristili tu oznaku ,ali mene zanima baš na Bf-109 i to upravo zbog te fotke navodnog "crnog 6" jel je na njemu položaj tog V bliže centru aviona ,a mene mući što bi se onda preklopio sa balkancem ispod krila (koji je najvjerovatnije bio prije zvonimirca). Pa me zanima eventuali slični slučajevi ,ove fotke di je V bliže vrhu krila sam vidio pa se nadam da netko naletio na kakvu fotku koja prikazije V u sličnoj poziciji kao na "crnom6" zanima me dali je V prefarbano preko Balkanca ili je balkanac pomaknut???
Alkett
Poruke: 104
Mjesto: Crikvenica
PorukaUpisano: Ned Ruj 06, 2020 11:10 pm    Naslov poruke: Citiraj ovaj komentar
Evo sličan slučaj, ali na mađarskome Bf 109 G6.
28. 11. 1944.
https://www.flickr.com/photos/28092068@N03/33447647796/in/album-72157641295482713/
Ovdje niže je profil Bf 109 G6 W.Nr. 167209. On je 2. po redu. za njega se navodi da je oznaka 'V' bila bojana preko mađarske i to prije datuma 31.10.1944. Prema serijskom broju je to G6 a ne G14. Znam, nije fotografija, ali postoji opis. Ne navodi se li prema sjećanju pilota ili fotki.
Profil sa opisom se nalazi i u 'Hungarian Fighter Colours 1930-1945. Vol.2
https://3.bp.blogspot.com/-WDneNT-ufA8/WOtNPA2NY0I/AAAAAAAAb7o/UTWpawV0UY0zfgBv6q4SwQMtsQ4tRXRVQCLcB/s1600/72174%2Binstr1.jpg
Inače ta mjere je trajala od 25.09.1944. pa do 'kasnog ožujka' 1945. Od tad pa nadalje je trebala biti prebojana i od tada samo žuti rep i žuti prsten oko nosa. To su sve podaci iz 'Hungarian Fighter Colours 1930-1945. Vol.2, MMPBOOKS.
Zanimljivo je da su kasnije počeli aplicirati 'V' kao i nijemci, s vanjske strane križa. No čini mi se na prvi pogled da to više nije prema standardnim mjerama iz naredbe.
Ovo je Bf 109 Ga14, mađarske proizvodnje. Datum 03.01.1945.
Pozdrav.
Alkett
Poruke: 104
Mjesto: Crikvenica
PorukaUpisano: Pon Ruj 14, 2020 11:48 pm    Naslov poruke: Citiraj ovaj komentar
Poky,
Da ne skeniram. 'Messerschmitt Bf 109 Vol. II' (Ciglić), strana 99. Fotografija na dnu. Zaviri pod krilo.
