Oboreni nad Jugoslavijom
Poruke: 1910
PorukaUpisano: Pon Sij 14, 2019 12:04 am    Naslov poruke: Citiraj ovaj komentar
Sutra (ponedjeljak) HRT 1, 20:05 dokumentarni film "Izgubljeni bombarder" o B-24 "The Tulsamerican"
10 dalmatinskih zapovjedi:
ZlatkoB
Član od: 29 Svi 2006
Poruke: 183
Mjesto: Zg
PorukaUpisano: Pon Sij 14, 2019 10:08 am    Naslov poruke: Citiraj ovaj komentar
To je materijal za zasebnu temu.
Laughing Pogledajte u Klubovi, natjecanja, najave, izložbe Laughing
Pozdrav Zlatko
Poruke: 1305
PorukaUpisano: Pet Velj 08, 2019 3:02 pm    Naslov poruke: Citiraj ovaj komentar
Možda nije baš materijal za ovu dretvu ali će možda nekoga zanimati ....
Sa prepiske na forumu Air Britaina ovih dana:
A member of Air Britain who is not on AB-IX has the following questions:
a) On 11/4/41 an SM 79 of the Yugoslavian A/F forced landed at Gruda airfield near Dubrovnik. Before it could be repaired it was captured by the Italian A/F. This was reported to British Intelligence in the Middle East by the co-pilot Dusan Miljus (apparently no relation to a contemporary Croatian journalist) on his escape.
Does any member know if the SM 79 enter service with the Italian A/F and if it did has anyone got a serial. Further what happened to Miljus, i.e did he join the RAF?
b) On 2/3/44 an RAF Spitfire of 73 Sqd was lost over Dubrovnik. 2 books have given different serials. A French book gives EN582 whilst Vol 4 of Shores et al Mediterranean Air War gives EN352. Apparently the 73 Sqd ORB at the PRO provides no serial so which one is correct?
Thanks in advance for any help,
David Brown
David,
EN352 was SOC in March 1945 some time after a crash at Perugia following an engine failure on take-off.
EN582 crashed whilst attacking a train near Dubrovnik on 2 March 1944.
Paul Reynolds
David
Can't help with your first query, but regarding the Spitfire lost near Dubrovnik, the Air-Britain EA-EZ serials book states that EN582, while with 73Sqn, flew into a truck while attacking a train 10 miles W of Grasac, near Dubrovnik.
A complication: I can't trace a Grasac - but I can find Orašac, which is further up the coast in the direction of Split.
Next problem: there's no railway there (at least, not now)!
EN352 is stated to have crashed on 16.12.44 at Perugia when an engine cut on take-off while with 5RFU.
Regards, Geoffrey Negus
Hi all
Gradac is a town halfway between Dubrovnik and Split. It is also on the rail line between the two. It was a base for Partizans in WW2. Possible answer?
Martin Degg
Zoran Petek
Član od: 09 Sij 2016
Poruke: 261
PorukaUpisano: Čet Velj 21, 2019 9:09 am    Naslov poruke: Citiraj ovaj komentar
27 iz 824 BS, 484 BG (44-49699) na Visu 21.2.1945.
Ovaj nije srušen, ali nije zgoreg podsjetiti se na tisuće onih koji su se spustili na Vis.
ino
Član od: 26 Ruj 2008
Poruke: 154
PorukaUpisano: Čet Velj 21, 2019 10:28 am    Naslov poruke: Citiraj ovaj komentar
Bilo je puno i ovakvih slucajeva na Visu i Prkosu. Video minutaza 6:10
https://youtu.be/acH7fpMz5ig
Zoran Petek
Poruke: 261
PorukaUpisano: Sub Ožu 30, 2019 4:02 pm    Naslov poruke: Citiraj ovaj komentar
Na današnji dan, 30.3.1945., tri Spitfirea IX iz 73 Sqn RAF (JL239, MK568 i MJ349) patroliraju Gospić-Zagreb i sukobljavaju se s miješanim sastavom NDH. (Dan prije su 2 Do 17 i 4 Bf 109 poslani iz Zagreba privremeno na uzletište kod Gospića za poderšku operacija protiv partizana.)
Pearce na Spitfireu MJ349 obara jedan Do 17. 73 Sqn navodi i jedan Fw 190 oštećen.
Idući dan ista trojka 73 Sqn ponovo patrolira tim područjem tražeči neprijateljske avione, ali na nalazi ništa.
Zoran Petek
Poruke: 261
PorukaUpisano: Sri Lis 09, 2019 5:48 pm    Naslov poruke: Citiraj ovaj komentar
Beaufighter 'F' iz 39 Sqn.
Pogled izbliza na serijski broj
Već sam davno prije rekao u jednom postu o Borongaju:
"10.10.1944. Šest Beaufightera iz 39 Sqn BAF napalo Križ, u blizini Zagreba, i oborilo Do 17 koji se spuštao na Borongaj. Obaranje je prijavio P/O I.D. Wallace, koji je letio na Beaufighteru X NT889/F."
Žrtva je bio Do 17Z W.Nr. 3240 9H+EL, Nahaufklärungsstaffel Kroatien. Hauptmann Georg Stark, Major Paul Lube (Fliegerführer Nord Balkans) i Gefreiter Helmut Fischer su ranjeni, a Unteroffizier Ernst Weise je poginuo.
Iz orb: "Almost clear skies and unlimited visibility enabled six Beaufighters to carry out an attack against barracks and sidings at Kriz, Yugoslavia, this morning. The aircraft led by Sqn Ldr Payne attacked the target and caused damage to three barrack buildings and 30 box cars in the sidings. As the aircraft were leaving the target they saw a Do 217 returning to Zagreb
aerodrome. Plt Off Wallace DFM attacked immediately, causing damage to the Do’s starboard engine and the enemy aircraft made a crash landing. It was again attacked on the ground and burst into flames as the petrol tanks blew up. Return fire was at first encountered from the Do’s rear gun,
but Plt Off Wallace silenced this during his attacks."
No bio je to i posljednji let Beaufightera NT889/F s kog se vratio čitav.
NT889 bio je samo jedan u nizu Beaufightera 39 Sqn RAF koji su nosili kod 'F', a u lipnju 1943. su zamijenili torpedonosce Beaufort.
Bili su to:
JM413/F Zapadno Sredozemlje, ljeto 1943. Naoružan torpedom. Povremeno na njem lete posade iz 47 Sqn, koje se uhodavaju u torpednim napadima.
LX883/F Zapadno Sredozemlje, jesen 1943. Kasnije u 47 Sqn, koji je preoružan torpednim TFX i poslan na istočno Sredozemlje. Pao je kod Lerosa u studenom 1943.
NE412/F Alghero, Sardinija, proljeće 1944. Naoružan raketama.
NE383/F Biferno, Italija, do sredine ljeta 1944.
NT889/F Leti na Paraćin 15.8.44., Solun 25.8., Sunju 2.9.44., Knin 19.9.44. Napada Križ 10.10., tad Wallace obara Do 17 nad Borongajem. Idući dan pogođen je flakom u napadu na torpedne čamce i slupao se kod Ancone.
NT998/F Leti na Novsku 25.10.44. Dok ostali Beaufighteri 39 Sqn lete na Bjelovar 2.12.44., NT998 prevozi 2 oficira u Nikšić. Nakon što je početkom 1945. godine 39 Sqn preoružan bombarderima Marauder, NT998 nadalje leti u 16 Sqn SAAF kao 'W'.
NT998/W 16 Sqn SAAF. Srušen je za napada 4 Beaufightera na Dobovu 8.2.45. Pogođen flakom krenuo je na sjever. Nakon što je ugasio motor nastavio je planirati još nekoliko kilometara i vrlo se grubo spustio. Posada (Bodley/McClelland) viđena je kako napušta olupinu, mahnula zadnjem Beaufighteru i krenula prema zapadu.
Pao je otprilike u tadašnjem graničnom području između III Reicha i NDH: Bizeljsko-Stara Vas-Kraljevec-Klanjec.
Rekonskrukcija NT998 u 16 Sqn SAAF. Boje su Dark Slate Grey i Extra Dark Sea Grey gore i Sky dolje.
'W' iz 16 Sqn SAAF na Prkosu. U pozadini Mustanzi IV 213 Sqn RAF, Balkan Air Force.
robertino1985
Član od: 05 Velj 2018
Poruke: 84
PorukaUpisano: Sub Lis 12, 2019 10:00 am    Naslov poruke: Citiraj ovaj komentar
Pad Bristol Beaufightera: Kako su se nad Senjom ispreplele sudbine Južnoafrikanca i Kanađanina
izvor [url]Novi list[http://novilist.hr/Vijesti/Regija/node_1586/Pad-Bristol-Beaufightera-Kako-su-se-nad-Senjom-ispreplele-sudbine-Juznoafrikanca-i-Kanadanina/url]
Citat:
Među ostalim, 10. listopada 1944. iz talijanske luke Biferno poletjelo je deset zrakoplova Bristol Beaufightera, savezničkih lovaca bombardera 19. eskadrile Južnoafričkog ratnog zrakoplovstva. Cilj im je bio pronaći i uništiti njemački brod »Arpione« za koji su postojale indicije da bi se mogao nalaziti u luci Senj ili u luci Novog Vinodolskog, a jedan od tih zrakoplova serijskog broja NT997 srušen je nekoliko stotina metara ispred luke. Olupina srušenog zrakoplova nalazi se dvjestotinjak metara ispred senjske Mađarske rive.
avtomoto
Član od: 17 Velj 2020
Poruke: 5
PorukaUpisano: Pon Velj 17, 2020 7:40 pm    Naslov poruke: Citiraj ovaj komentar
Pozdrav vsem,
sem novi član na tem forumu in imam vprašanje. Ali kdo pozna ("ime" ali s/n številko) za ta dva bombnika iz Visa ?
Hvala za pomoč.
Ivan
[img] https://www.dropbox.com/s/ymtlg48cp162gh7/B-24%20_Vis1944.jpg?dl=0 [/img]
in
[img] https://www.dropbox.com/s/j84x1chgl7yu44s/Pic1_36%20B-24.jpg?dl=0 [/img]
Poruke: 1379
PorukaUpisano: Uto Velj 18, 2020 8:39 am    Naslov poruke: Citiraj ovaj komentar
Nažalost Ivane usprkos puno truda i traženja nisam do sada uspio identificirati ova dva B-24; možda u međuvremenu izroni još koja fotka gdje se vidi malo više? Inače B-24 sa simbolom mazge ili konja na nosu snimljen je na stajanki sjeverno od poletno sletne staze a ovaj drugi, broj 36, na otpadu istočno od staze.
Zoran Petek
Poruke: 261
PorukaUpisano: Uto Velj 18, 2020 9:58 am    Naslov poruke: Citiraj ovaj komentar
Ovaj drugi broj '36' je iz 451 BG 726BS, serijski broj' 41-28955, ime KLUNKER. Prisilno se spustio na Vis 13.10.44. Pao 17.11.44.
avtomoto
Poruke: 5
PorukaUpisano: Uto Velj 18, 2020 12:53 pm    Naslov poruke: Citiraj ovaj komentar
Zoran hvala za informacijo. Sedaj grem s pomočjo "strica Googla" v iskanje fotografij "Klunker"-ja. Upam, da bom našel še kakšno fotografijo tega bombnika !? Confused
avtomoto
Poruke: 5
PorukaUpisano: Uto Velj 18, 2020 5:39 pm    Naslov poruke: Citiraj ovaj komentar
Zoran, glede iskanja bombnika "#36" v mojem postu sem dobil drugačne podatke. Očitno na fotografiji NI #41-28955 "KLUNKER". Prilagam dva mnenja:
"Sorry Ivan. Good thought, and it was indeed #36, but 41-28955 was a Douglas (Tulsa) built aircraft, and the #36 in the image
is Ford-built and that damage was beyond the Vis crew to repair.
Bob"
in
"Regrettably, this specific #36 isn’t the same as #36 41-28955, an earlier a/c assembled at the Douglas Tulsa plant in Oklahoma.
The #36 seen in your photo is a later model, which certainly was manufactured at the Ford Willow Run plant in Michigan.
It is either a late J-FO, or an early L-FO; the Group belonged to the 49th Bomb Wing, probably the 451st BG....
Gino"
Lep pozdrav
Ivan
p.s. Iskanje se nadaljuje . . . ?!
Confused
Zoran Petek
Poruke: 261
PorukaUpisano: Uto Velj 18, 2020 9:36 pm    Naslov poruke: Citiraj ovaj komentar
Isprike svima, moja greška. Već dugo imam tu fotku s (olito krivim) potpisom "36 Klunker", a nisam provjerio detalje (jer je bio na Visu, a i oblik oznaka odgovara 451 BG).
Još jednom isprika.
Zoran
Poruke: 1379
PorukaUpisano: Sri Velj 19, 2020 8:30 am    Naslov poruke: Citiraj ovaj komentar
Dakle oba B-24 sa Visa ostaju do daljnjega bez identifikacije...
Stranica 4/5
